Ok, so you get any part you want, shown in this picture, that I can fit in a Large Flat Rate priority mail box for $100 + the $15 flat shipping rate.....gotta leave some room for packaging material though.
Here's what you're seeing from top to bottom, right to left:
- 08 led tailight
- necessary wiring to wired your fan to a switch
- 08 display
- 08 coil and plug wire
- 08 lean angle sensor
- neutral light sensor/connector
- ground cable
- ignition switch with key
- 08 front master brake and lever
- 08 front calipers
- 08 starter
- stator cover with flywheel, one way gear, and stator
Call or text 910-489-2003
did it all go? I need the ignition switch and key if you still have it.
Jeremy
