I guess if you like to do this again in the future you can use stock parts. But you need to get a good after market carrier. RPM makes a super heavy duty carrier that can take what ever you throw at it. 928-771-9363 ask for Brad.hey guys thanks the heat work really wel.can you tell me is the rear hub and the carrier the same thing .because everything inside there was shot and i need to replace it so i want to get the right parts.i alll ready have bearings and seals.but the left side i bleave that it is the rear hub and the spacer in there completely trashed.
thanks so much guys
I found the first time apart to be bad, after that I haven't had a problem with the stock carrier, although I probably maintain it more often than I used to knowing what a bitch it was to get apart. I found putting everything together with assembly grease seems to help keep it easy to get apart.I guess if you like to do this again in the future you can use stock parts. But you need to get a good after market carrier. RPM makes a super heavy duty carrier that can take what ever you throw at it. 928-771-9363 ask for Brad.
