1 - 7 of 7 Posts
Its been sitting for over 8 months, installed a new battery, and i try starting it and it wont start. I checked the plug, and it is just black and its dry. I cleaned it up and put it back in and same thing again, just cranking not turning over.
So now am thinking its not getting fuel. I have about a half tank of gas..
how to i check to see if it's getting gas?
thanks
Premium Member
You should be able to here the fuel pump cycle when you turn the key on with out starting it
If you don't here it check the fuse under the seat
That's the easy stuff to check first
The gas is probably bad dump it all out and put fresh in it. If that's not it the injector is prolly clogged. That's why u can't let them sit up
Premium Member
The 700 Raptor dumps a lot of fuel on start up, if the plug even thinks its going bad, it won't start, might pop a couple of times but will not run. Try replacing the plug. Hope that helps!
1 - 7 of 7 Posts
