I have a 2007 Raptor 700 with a FMF powerbomb header, K&N filter without airbox lid, and a FMF programmer. It will not idle or run. You can get it to run for like 5-10 seconds by messing with the throttle. The TPS is .6v at idle and 3.9v at WOT. The valves have been set and the timing marks are in line. Compression Test is 90psi and manual says 64psi. Fuel pressure is 47psi, and even tried running it off a canister set at 50psi and made no difference. It just pops out the intake and wont hardly run. I have also unplugged the FMF programmer and it made no change. Im running out of ideas any help is greatly appreciated!
Discussion Starter #2
So did a leak down test and it was good, less than a 5% drop. Also pulled the side cover off to check the flywheel key as the flywheel nut kept coming loose during the leak down test. So still runs crappy and wont even really idle, with or without the programmer makes no difference.
