Looking to build my 08 raptor duner/drag wanting to stick with stock stroke bore my goal is to reach 70-75hp Also building it to be reliable, on a 3k budget, I do not want to run race gas if possibe, Elevation where I live 52' mainly ride at oceano dunes,
Im pushing 70/71 hp on 2/2 head, 5050 cam, dual monsters,fci and 734 bb with 11:1 piston with pump gas and its reliable. Was over 3k though. Sure you can get close
I have a 2008 raptor 700 Sb/ss +1 head 500 lift cam,big three, fci, duals, MSD ,14:1 comp, +3 TB making about 71-74hp On 110 octane Depending on how hot the motor is. The bike has been great. I drag race the heck out of it and dune and trail it. I do worry about the stock rod giving out though. 3k would Get you fairly close. With used parts I’m sure it’s do able. a good -head-and cam is is usually about 1300 from a good builder. A good big 3 is usually another 1200-1500 depending on what exhaust you go with. I run DMC force 4s I really like them. but if I could do it over I would go with monster big core duals. 3k should cover head cam and a big 3 setup. The stock rods have been known to hold well up into the 80hp range but with it being an 08 it pry has a lot of ride time on it and it’s a guessing game on how long the oem rod will hold. I would suggest getting a falicon rod or crankworks rod trued and welded if you get some extra cash. Stay away from (HotRods cranks!!) So far I have been lucky with my stock crank but I would like to get a falicon in the near future. If you are really on a strict budget and wanting around 70hp I had a 12:1 piston hc3 +3 tb and big 3 build that made 64hp on a stock head. I think if you run this setup with a good stock valve port you could see 70 or very close to 70hp and accomplish this very well under the 3k mark and would be extremely reliable build.
Stock bottom end is pretty stout actually....I am still on my stock bottom end and I have run about a 100 pounds of spray (30 shot) through mine, had it apart last year and the crank and rod were well within spec. I am 14:1 and run a 50/50 mix of 110/93.
Related Threads
Modded Raptors Forum
239.1K posts
13.2K members
Since 2008
A forum community dedicated to Yamaha Raptor ATV owners and enthusiasts. Come join the discussion about troubleshooting, classifieds, performance, modifications, maintenance, and more! Share more about your favorite model including the: Yamaha Raptor 700, Raptor 660, Raptor 350, Raptor 250 as well as the smaller Raptor 50, 80 and 90.
