Hello my name is Kaine,
Just got a new raptor 250, want to do some mods to it but not sure where to start. But it is shifting hard. sometimes wont go in neutral or 1st or 2nd. then somedays it will shift perfect. what should i look for when i take the motor apart? also where should i start? Thanks anyone that helps. Have nice day!!
I am guessing its not "New" but new to you. They don't make the 250 anymore unfortunately. First thing I would do is change the trans fluid. It may have the wrong or no fluid in the trans and the temps could be causing issues with the wrong fluid. Make sure the shifter is not bent and hanging up on anything. Then I would check the shift shaft. Not sure which side the chain is on the 250 but if the change comes off and hits the shift shaft or cases, it could bend the shaft. That's where I would start.
