just got my crank back from CWI. its a 8mm stroker balanced with rod and piston,rings wrist pin. my question is do i need to use balance shaft? big end of rod hits the balance shaft. ya'lls help is appreciated .thanks
Discussion Starter #2
well i got an$1000 paper weight.would anyone like to buy it.cause i can't use it .carrillo makes rod bigend thicker because they sleeve their rods.i can't return it because of special order,no help what so ever.did ask Skip dowling to order a rod for 8mil stroker crank with standard size ends.skippy doesn't care that he made a mistake when ordering my rod.don ,at carrillo, skippy,told me nothing about standard size was mentioned. i did get upset. crankworx did a great job put it together. will buy from them,not SKIP DOWLING at orient express, ever again.my opion is he doesn't care about his customers
