1 - 11 of 11 Posts
i have been working on a 660 that a guy jacked up the wiring on. first there was not power going to the key switch, so i replaced the reverse sensor and the other sensor on the bottom of the motor that has a ground on it, then replaced the starter relay, and that fixed the problem. had power to the key switch and it would turn over. i unhooked the battery put the rear plastics back on reconnected the battery now when i press the start button the red oil light just lights up and does nothing???????????????:wtf: i have checked all the connections twice, could the cdi be bad? anyone ever had this problem?
u have a bad conection on the male sensor thats down behind the shifter. u can unhook it cut the wire and ground it to the frame
hope that works 4 ya. hope to make outlaw but with the price of gas on the rise and business going down hill its not looking good
well that was not the problem, so there is still a bad ground or something somewhere, could it be the cdi?
hmmm. sorry bro i thought that would fix it? anyone else got any idea's?
Had this same exact issue, the start button works, oil light comes on when you hit it..nothing happens. I'm 99.9% positive your problem is the huge clusterf&%k of wires behind your battery, with the 3 plugs going into your cdi. Take your cdi out and pull those plugs, check out all the wires. Those wires tend to rub on the plastic and on each other...bet you'll find the culprit back there. When and if you find the issue back there, when you put it back together make sure to wrap the wires decently and make sure they're not rubbing on anything.
-Before you rip into it, try turning on your lights and starting it..try low and high beam. See what happens, I'm not a wiring expert by far but that might give you an idea of where to start looking, follow the colors if thats the problem.
i had the same problem and i found 3 wires on one of the plugs at the cdi box where shorting out i fixed them and wrapped them up with tape and it's been fine since
Do you hear a click from the starter relay? If so, short across the two large lugs on the relay with a screwdriver or pair of pliers (ignore the sparks). Does the starter turn now? If it does, but you only hear a click when pressing the start button, the relay is bad.
If you hear no click, then it's a little more complicated, but still manageable... just let me know.
BTW, does your neutral light work? If not then it could be the neutral switch wire connection - pull the clutch, does it start now?
Also, does the reverse light work? If so, the CDI is getting proper power from the run/stop switch and has a proper ground connection.
And Friday - there is no oil light... it's the temperature light. BTW, I AM a wiring expert. It is about 99.9% not CDI related.
Hi QuadManiac, I have the same issue with my Raptor 660... I don't hear the click in the relay. My neutral light works normally and the engine starts and runs normally when I short the relay with a screwdriver...
I don't know what else to check
I am new here, just bought a raptor 660 from a friend that told me when they were riding it he went in a puddle that was deeper than what he expected and it turned off and wouldn't start back up. It has also been sitting uncovered in the rain. So I bought a new starter solenoid and put it on and a cdi box and i took apart the start switch which had some corrosion on the contacts. Cleaned them with some sand paper and that is when I noticed the switch for neutral and the other lights is gone. So what i am wondering is does the bike need that switch because it has done absolutely nothing no click no nothing. I have also charged the battery. When i took the start switch on the left handlebar apart to clean it i noticed that the headlights were sorta shorting out they only came on dim if at all. that was with flipping it on and off i guess between settings it made contact a little and came on. Now with it having that neutral light thing gone i just need to know if anyone thinks its that , that is stopping it from getting power. well i really don't know if it is not getting power because i don't know how to use a multimeter. i have one just don't know where i should set it etc. Any help would be appreciated.
1 - 11 of 11 Posts
