16 amp @5000 rpm
upgrade battery too if you decide to run more lights. wire on off of battery with relay or inline 15amp fuse, to a switch on bars then to additional lighting. remember to use heavy gauge wire or you with melt harness and new wiring. turn off secondary lights during day riding and on for night/dusk use. LED is the way to go as well, low voltage/amperage.
good luck
