I got a no start issue. no spark, but it turns over fine.
its code 33, ignition coil. I followed the service manual and the coil is in spec...
I traded the coil wires... the orange to the ecu is continous, and the red/black goes to the switch and is continous. I did not check to see if either were grounding. hmm...
does anyone have any other off the wall ideas on this, I checked all the fuses, and all the relays appear to be functioning, I just have no spark, I verified this by using a spark plug and cranking while touching it to the motor block, just like on a car
im hoping its not the ecu.
Im not getting codes for the crank sensor, or the tip/lean sensor, so i am ASSUMING those are ok... can they go bad and not cause a code?
this thing is starting to PMO!!!!!
