calling sto, basically, cuz im sure he has lots of knowledge on these things(and of course antibody els whos knos about cams)
heres the deal, my stage 2 HC broke, so ima haft get another cam, yes i liked the power band pretty good, but how much bottom end will i loose by going to a stage three? also will much top end be gained from a stage three on my set-up?- im running a trail ported head, 11:1 piston, stock carbs with open element filter, and barkers....
i still need to pull off the head and check the valves and piston, and i most likely will stay on pump gas
i have researched stage2 vs stage 3, and have read diff opinions, jsut wanting a bit more insight........
-also, are the x3 and/or the web 685 cams worth looking into? and how would they compare to the stage 2 or 3 HC?.....
thanks guys
thanks guys
