My 2008 Raptor 700 has a cooling system problem.
The coolant is collecting in to the coolant reservoir and pushing out the vent tube.
I took the radiator cap off the started it. I let it idle and could see the coolant start to move in the radiator. Then the coolant just poured out of the radiator from the cap hole. I turned it off and it gave a big belch and a little more poured out.
I took the thermostat out and put it in boiling water and it opened up. Put it back together did the same thing as mentioned before and the same thing happened.
I just put a cam, piston, and +1 head on it. I’ve been riding it with no issues till just the other day when I saw that coolant had came out of the reservoir vent tube and all over the front end.
Thanks for looking!
Any ideas?
Thanks for looking!
Any ideas?
