1 - 11 of 11 Posts
Hey guys, need a little help here, I installed a set of FCR 35's and they don't quite clear the header pipe. I'm currently running a full GYTR system, can anyone suggest another brand the would allow enough clearance for the accelerator pump ?
make a dimple/dent in the pipe to clear the pump......and/or pick up the trinity intake spacer...it will move the carbs to the left and down...allowing clearence...
Yes, but it does shift the filter back about an inch or two...I don't use the factory airbox, I use an adpter to run my K&N...
here is a rough pic of the spacer
Discussion Starter #10
Thanks for the info, but its too late, I already picked up and installed the Trinity manifold.
Its not all that bad, it moved the carbs just enough to clear the header. I needed to run the stock air box still, mainly because my fuel pump and nitrous solenoids are mounted in the box.
Can anyone give me a starting point as far as jetting with the 35FCR's ?
1 - 11 of 11 Posts
