1 - 20 of 21 Posts
ok well not that bad but i was riding down the trail and hit a stump i didnt see. it ended bending the tie rod, slashed the tire and possibly bent the rim.... we were able to get it bent back to semi-straight, and i was able ride the rest of the night. i crashed it twice before we got it fixed cuz with it toe'd out so bad i had very little control.. lol. .
i'm fine, i did go flying off the quad but it was as graceful as any fall i take.. like a ninja, the dirt said ouch....
But i was shocked to find out the tie rod is hollow.... does anyone make a solid aluminum tie rod???
e bay....for the alum....i would stay with the stockers though....just keep some extra around.....coulda been worse
ya it could have been way worse.... i'll call the stealership tomorrow and find out what i'm looking at to pick up a replacement plus spares.
dam man good to know you didnt get hurt luckily i havent rolled my rappy yet and i ride hard as hell almost every weekend if not more since ive had it for almost a yr now
check out Motosport.com for lots of aftermarket piece. Many different brands.
Glad to hear you arent hurt.
Discussion Starter #9 (Edited)
Sucks that you wrecked bro but from one dumbass to another buy some skids. ASAP. WOODY
I found some stainless steel (solid) from Lone Star Racing at Motosport.com.:banana: I think they were like $90 for the pair, but the stockers bent too easy for me. Got these after I bent 2 stockers from just hitting decent sized rocks.:wtf: My only concern is now it may bend the a-arms instead of taking out the tie rods, but that's OK, because then I have the perfect excuse to upgrade the suspension.:thumb:
Discussion Starter #13
Here is what the tire looks like..... is this too far past repairable? it still holds air.
3 choices (number 3 is ultimately the one i'll choose but i'd prefer to do one of the first 2 first.
1) ride it as is.... maybe fill the hole with epoxy
2) tube it.
3) the tire is trashed, you NEED to buy new ones.
I wouldn't say you "need" to buy new tires, I rode with a plugged sidewall for a couple months and it held air just fine.
That said, you will notice a different in performance when you get rid of those stock tires. If you've got the cash I would say it's a good excuse to buy some holeshots or some razrs, if not it shouldn't be a big deal.
Sometimes it is better to loose a cheaper part (Tie rod) than the much more expensive part it connects to. Just a thought.
Discussion Starter #17
the tire doesnt have a hole, so it holds air and a plug wont help, i dont think i can afford new tires this month.
ya i think i'm going to keep with stock tie rods.
I am smarter than you....
a solid cylender isnt as structurally sound as a tube. that is the reason it is hollow. and keep the steel ones.
Wow that is a deep gash in your tire. I'de say its close to ripping open. I would not trust it to far.
1 - 20 of 21 Posts
