I run IShock and have had no issues. They are +4 set up and really absorb the hits well. They come in complete kits with shocks or just suspension only. I race offroad desert so we need something that has to work and these do! Good luck...I'm looking into getting some wider A-Arms. My question is when they say +2 does this mean each arm is 2" longer making the front end 4" wider? Or is each arm 1" longer making the front 2" wider?
+2 means, 2" on each side. You should also think about looking for a rear axle. And when it says +4 on the axle it means 2" wider on the rear.I'm looking into getting some wider A-Arms. My question is when they say +2 does this mean each arm is 2" longer making the front end 4" wider? Or is each arm 1" longer making the front 2" wider?
Yes, just a little.Thanks, I don't know witch ones I'll go with. Seen some on ebay. Do the wider arms also lower the front end?
