So i thought my clutch had given up on me... Turns out it was that little gear inside the clutch cover... where can i buy that and what exactly is it called???
Try dirtcheapyamahaparts.com
Premium Member
It is called the axle push lever, the Yamaha part number for it is 5EB-16382-00-00, retails $42.69, your local dealer should be able to get it, or you could check eBay! Make sure the grooves on the shaft sticking out of the pressure plate are ok too, its called the push rod and the Yamaha Part number is 4XV-16356-01-00, retails $27.95. Hope that helps!
