So Wont start, turns over fine but wont fire. I checked valves, and all electrical connections including ohm testing , all seems to be fine. I pulled the plug which was a little wet but I got spark. compressions good, and theres fuel in the fuel rails with pressure, but no fuel coming out of injector. I tested that by pulling the injector out of the throttle body but leaving it attached to the fuel rail and turning it over to see if it squirts fuel. Still nothing, and yes the fuel pump is working just fine. I tested tps sensor aswell, its perfect.. I attached a 12 volt battery to my injector and it does click...coud it be completely clogged?? Please someone help!
Sent from my SM-G955U using Tapatalk
