For those of you who do not know Yamaha has a speed sensor installed into the transmission. What it does is in 5th gear at somewhere around 7500 it starts de-rating your timing and ultimately governing your top speed. This modification is geared for those of you who have done performance mods like the “Big 3” and more. On a stock Raptor 700 you won’t see the benefits as much.
The only thing you will have is a sensor in your transmission with 3 wires about a foot long that you will need to tie up.
Where to find your speed sensor.
On top of the engine, drivers side, to the left of the serial # stamping.
Benefits:
Top speed should increase 6 - 9 MPH
Affects:
If the check engine light comes on, you will need to plug it back in... then roll forward a few quad lengths and the light goes out, then unplug it again.
Modded Raptor would like to thank Shredder770
Benefits:
Affects:
