Better yet where to relocate parking brake lever.To be able to keep it and use asv levers.
I bought a Rox Ring cam lever and mounted it off the handlebars on the left headlite/fender bracket......However, the Rox ring is designed to replace the the stock lever, so you can mount hand guards, etc. I have ASV levers, but the reason I used the Rox ring was I went to a +4 swingarm and wanted to keep my P-brake, hence the relocate to bracket.Better yet where to relocate parking brake lever.To be able to keep it and use asv levers.
I connected the two wires together to allow it to start in gear ...no longer have a "neutral safety switch"..............SandaddyYeah thats a very clean install,with going to the asv levers.what happens to the,i guess its the switch to keep from starting in gear?Thanks to every one ,kind of anal about messing with my rappy. i don't want to jury rig shit together. you guys are a tremendous help!
