The following is quoted from Limited660, i should take no credit for this
Ok, first locate the left headlight, it looks like this.
Take the headlight off and follow the wire from the top of the clutch perch down inside and tug on it while watching the wires, you should see and white plug with 2 wires going into it behind the bracket that supports the radiator. Unplug it, you should now see this. The plug is outlined in yellow and pink.
On my quad, I took the whole wire off the thing. To do this you need to remove hood, then undo the 2 wire clamps, 1 on handle bars, 1 by steering stem. Now on top of the sensor at the perch, you need to push in a tang and pull at the same time to remove it, now pull it out and put the wire clamps back on and put it all back together. The wire you took off should look like this.
Your done, enjoy your riding free of engine cutting out.
