KFX450r looses power
1K views 1 reply 2 participants last post by  madracer3600
#1 ·
I was running a banshee the other day on the street and towards the end of the run my bike jus shut off but it started right back up... Some people told me that its the resistor in the plug that gets hot and kills power(CPR8EB-9)... so i was looking for a plug without the resistor in it... What would be a good plug that would hold up when i spray... Some people told me NGK Iridium plug but idk?
#2 ·
on the my motorcycle went away from iridium plugs. If you want a ngk plug the r in the number on plug indicates the resistor is present. If you get the same plug with same number without r in number. it is the same heat range. As far as iridium or not it is user preference. But sounds like you got another problem. But best of luck with plug!
