1 - 6 of 6 Posts
Hey guys.. I buy a 700r 2012 five days ago. At the moment the bike was working fine but after some rides the quad start to fail.
I can start without problems but after 30sec the motor power off. If a accelerate sometimes go off and sometimes make some backfire and go off again.
I replace the fuel by new one and clean the filter inside tank. I check the fuel pump and works fine.
The battery is new.
The spark seems to be fine.
The previous owner doesn use a lot the quad. Maybe can be a problem of dirty inside the injection system? Or spark ? Or electrical issue?
The quad is original only have sparks exhaust.
Thanks and regards!
I'm sorry to hear that..... how does the plug look, oily or sooty or what...it could be running too rich or too lean, in which case u may wanna change plugs or something.
Check the neutral and reverse switches and check your stator connectors as well.. it could be a multitude of things..test the stator, if you have a ECU from a friends bike and you know it’s good swap them out to see if your ecu went out..the valves could need adjusting.. it all depends, gotta go through it and troubleshoot
Discussion Starter #4
hey guys... i check the sensors and are fine. Also check the fuel pump pressure and is working with 50psi so that is OK. I clean every connector with contact cleaner and remove the inyector, cleaned and is ok too. The only thing i cant change now is the plug because of coronavirus is all closed here. But something strange is if the quad is with stable rpm at 3 gear, and i change to 4 gear, start to backfire.
thanks!!!!
Discussion Starter #5
the problem was the plug. I remove again but this time decrease a little the gap in the plug. Now the quad is working fine. Thanks to all.. Any knows how to close this post? or is not necessary
The battery is new.
Thanks and regards!
Yikes, that must be difficult, sorry to hear about that. I hope you have fixed it this time.
1 - 6 of 6 Posts
