doesnt doit all the time i have n hmf slipon n motoworks efi controller does this mean its to rich or to lean still have stock air filter but getting a knn if that matters thanks for any help.
you were lean to start out,and the guy leaned it more??I use to run a pcIII with a 2 bros slip-on and the map fuelmoto preloaded for me. It would pop after I would hammer on it and let off and let it rev down. I got it dyno tuned and the tuner said he leaned it out in a few places and the popping was gone after that. So, what I'm trying to say is when mine did it I was lean. Try and lean it out a little, just keep an eye on your plug :thumb:
Yeah I think he messed up what he was trying to say there...you were lean to start out,and the guy leaned it more??
im guessing the map was rich.. if he had no controller it would of been lean.you were lean to start out,and the guy leaned it more??
EXACTLY! I f*cked up at the end of my statement. Popping when rich, then the tuner leaned it out and the popping was gone :thumb:He meant he was rich and got the map leaned out on the dyno tune is what it sounds like.
Weird.....mine popped a few times on a long ride and I pulled the plug and it definitely wasn't rich....I guess popping may not be a sure indicator either way...rich or lean. Glad you got her lined out.EXACTLY! I f*cked up at the end of my statement. Popping when rich, then the tuner leaned it out and the popping was gone :thumb:
like i said earlier...if it pops out the airbox...it means its popping out of the injecters/ or carbs....thats lean....if it pops out the exhaust your running rich....from the previous statement of dynoing and leaning it out after this would indicate my statement to be correct as he was back firing out of his exhaust..:banana:Weird.....mine popped a few times on a long ride and I pulled the plug and it definitely wasn't rich....I guess popping may not be a sure indicator either way...rich or lean. Glad you got her lined out.
