:banghead:The other day I sunk my raptor at a local riding spot. It didn't go completely under ,just from the rear fenders to about halfway up the airbox(no lid :thumbsdown
.I killed it before any water went in through the carbs but when it died it sucked alot of water up the tailpipe and hydrolocked the motor. So far I've spayed WD-40 down the cylinder and put a little bit of marvel mystery oil down there, drained and flushed the oil 3 times with new filter each time(just a little bit of water in the oil the first time I drained it), cleaned and re-packed the exhaust , drained the antifreeze, replaced the waterpump seals and bearing(needed to be done anyway)and cleaned the carbs just in case.
Was wondering if I needed to do anything else?
