Oversize gas tank
8K views 11 replies 9 participants last post by  Ryans' Roostin' Raptors
#1 ·
Has anyone built an oversize gas tank for the Raptor 700 yet?
thanks.
#3 ·
Anyone try taking apart the stock gas tank to remove the fuel pump and installing it in an aluminum tank or anything like that? I would like to purchase a Raptor 700 because I feel it would be the best quad for the long distance racing I do, but the fuel capacity is just too small. There has to be someone out there that got creative with this. Is there much room on a Raptor for an oversize tank anyhow? Can you hook up an external fuel pump outside of the tank? Someone has got to have tried this!!!
#4 ·
i have read about this before and it was said that yamaha stuffed the biggest tank possible that you could have without removing plastics and interfering with the handlebars
#5 ·
there was one guy trying to do them but fucked a bunch of ppl. from what i hear there is not enough room for a good ammount of improvement.
#6 ·
I think if you were creative enough you could make a bigger one. There is what i would say about 1 and 1/2 to 2 inches the gastank could be extended down between the frame rails as long as you insulate and leave a channel for the throttle cable. And maybe some in front. But i am to lazy to do all that and you will only get a half gallon or so. But in racing doesnt every little bit help. I will just lift the gas can more till someone else makes one.
#9 ·
Nope. Along with a high output stator, it is just one of those things that aftermarket companies won't produce. And I hate it.
#10 ·
couldnt you kust put a r1 tank under the plastics they do it all the time with the r1/r6 conversions?
#11 ·
No they don't do that all the time.
