So I have a 2012 250 yfm but can only have one light on at a time when I put dipped beam on one light comes on but when I press the high beam it switches to the other light and the dipped beam light goes out is the any way I can get both head lights on at the same time just on dipped beam?
Check the wiring to the headlights. Sounds like it's not wired correctly.. You should have a 3 wire plug ground / low / high. Unplug it and check for current at both... :thumb:
