I have a 2007 raptor 700 . The bike had been fully restored and modded . I went to go start the bike after sitting for a while and after trying again and again, the battery stopped making that clacking noise and went quite. Now when I press the start button the bike does nothing or makes no noise. It only shows the check engine light. It dosent even pump gas when I turn it on. Please help
Premium Member
Make sure the small ground wire from the battery is plugged into the harness, usually its just in front of the battery. It's a single wire connector. Also check all fuses as duning4life suggested. Make sure the battery is fully charged as well. If you tried starting it several times with low voltage, it's also possible the starter relay has went bad.
