1 - 11 of 11 Posts
i want to put in a higher compression piston in my cylinder. I know i need the rings pins and gaskets is there anything else i need to get? Can someone help me out because i really dont know much and i need directions or tips on what to do.
a decent torque wrench is at least 100$,,,,feeler gauges, parts cleaner, silicone, loctite, service manual, piston ring file.....it all adds up quick....the job is not that hard but if u are not familure with motors then it is best to take it to a dealer for the 250$
use the book and start taking it apart....it would take for ever to write all the little things to do......start on it...when u run into a problem then ask..
i have one last question i know when you get into the top end you need to re adjust the timing chain is tht hard?
this motor uses a self adjusting chain tensioner, so no adjustment needed....as far as cam timing...line up the marks like the book says and u will be fine
1 - 11 of 11 Posts
