Hi guys I'm working on a 2007 raptor 250 when u start it up it back fires in the carburetor when cold once you worm it up it starts having Reilly high reving I sprayed starting fluid all around the motor to test for vacuum leaks did not change and cleans carburetor please help
It sounds like you need to clean the entire fuel system, dump all the gas out and clean the carb and see if that fixes it.
