1 - 20 of 21 Posts
I'm tired of looking at this quad sit in my garage. If someone wants the whole thing I'll take $4k no less. If not i'm parting it out. I will sell the motor complete or in pieces. Its a 2007 with a 907cc motor. Started smoking last trip out. Still Fires right up. Prices do not inlude shipping.
Complete 907 Motor from Intake to oil drain Plug Includes K&N Filter & Intake, ARP studs, Custom ported & o-ringed head with +2 valves, copper head gasket, webcam, CP 108mm 14:1 stroker piston, Barker +15mm stroker crank, machined block, machined counter balance, 58mm dual injector throttlebody, 650cc injector, Direct Drive lockup, Factory Yamaha Clutches. $3000, $3500 w/ Monster Duals, PCIII, & Dynatek Programmable Ignition
108mm Tall Cylinder from Racer's Edge $600
108mm CP Custom Milled 14:1 Stroker Piston $150
Web Cam $200
Ported & O-ringed Head w/ +2mm Valves & clearenced rockers $800
ARP Studs $60
Extended Timing Chain $50
58mm Throttle Body $300
650cc Injector $50
Barker +15mm Stroker Crank $400
DirectDrive Lockup $350
Yamaha Clutches and Friction Plates Almost new $100
K&N Oversized Intake, Filter, & Outerwear $85
Monster Dual Exhaust $300
Power Commander III $150
Dynatek Programmable Ignition $150
Skat Trak 10 Paddle Haulers, Front Mohawks, With Black Drag Cut rims $300
Chariot Racing Peg Mount Chain Tensioner $75
+10mm Extended no-link Swingarm with solid strut Raw Needs powdercoating $175/ $275 with chain & extended brake line
Billet Carrier Bearing $75
Moose Racing Large Black Pegs $75
Stock Piggyback Resevoir Shocks Front & Rear $250
Stock Swingarm $50
Stock Axle $25
Renthal Raptor Bars w/ new Grips $25
Front Brake system Complete $150
Parking Brake block off $20
Rear Brake system $50
Stock seat has a small tear $35
Factory Black wheels & Tires pretty rough! $100
Nerf Bars need Paint or powdercoat $50
Stock Frame no title $150
subframe $75
New Battery $50
Stock Oil Canister $40
Are the a arms and rear axle stock or wider? Did I miss the location?
Exhaust is just old and dirty. It has spot for an 02 sensor for tuning on the right header pipe. Pm me your cell # and I can send you some pics of it tomorrow
Interested in dynateck ignition. Do u have the programming cable aswell? Pm me ready to buy
Sent from my SAMSUNG-SM-G900AZ using Tapatalk
Still have the Renthal Bars? Pm sent
1 - 20 of 21 Posts
