The final 2 bikes have been chosen and now its your turn to make the final decision. The two selections in no particular order are:
derrickderrick19
700 Based model
Mod List:
Turbo 700 Raptor
D7 dual injector turbo
Ragged edge turbo cp piston
Direct drive ninja lockout
Drag cut and lightened chassis and subframe
Candy blue powdercoat
Chrome stator cover,cam cover,water pump cover,oil filter cover,brake master cylinder,rear caliper,oil tank,motor mounts
Slc ladder swing arm
Fox float fronts
Marvin shaw rear
Cuervo racing brake pedal
Jja axle
Typhoon rotor
Lightweight chrome upper and lower arms
Drag cut spindles
Custom steering stem with mt bike bars
Odi grips
Direct drive front and rear wheels
Sls haulers and fronts
Autometer boost and afr gauges
Throttle Jockey
700 Based Model
Mod List:
81.0 HP
8 MIL Stroker crank works
105.5 CP PISTON 12.5:1
Web 4 cam
PORTED HEAD PLUS TWO VALVES
54MM WK TB
DIRECT DRIVE LOCK OUT
6" SWING ARM custom owner built
Monster Big bore
POWER COMMANDER 5
Hybrid hydrographic coatings
Trail tech hid lights
AVS levers
custom seat
**If any of the two nominees want to add any pics or descriptions at any time let me know**
derrickderrick19
700 Based model
Mod List:
Turbo 700 Raptor
Fox float fronts
Marvin shaw rear
Jja axle
Typhoon rotor
Drag cut spindles
Odi grips
Throttle Jockey
700 Based Model
Mod List:
81.0 HP
Web 4 cam
54MM WK TB
Monster Big bore
POWER COMMANDER 5
AVS levers
custom seat
