1 - 5 of 5 Posts
· Registered
Haven’t had any issues the day before
went to start and it won’t start. Gave it some starter fluidand ran for a few seconds …
Can’t hear the fuel pump on key turn
replaced spark plug
Still no start and also checked fuse is good
running on power commander 5
· ROTM Administrator
Check the fuel pump for power at the connector on the fuel pump. It should get power for about 3-5 seconds when you turn the key on and should also have power at the pump when you push the start button. If it does than your fuel pump has gone bad which is a common problem on the newer models. If there is no power than check the fuel pump relay and fuse. That's were I would start looking
1 - 5 of 5 Posts
