1 - 10 of 10 Posts
SO U THINK ITS OK TO RUN WITH NO AIR LID AND NO SPARKY>>>>>>with no fuel controller
did some dyno runs today, and using the maps from the power commander site this is what i came up with, before and after with the power commander mapping
they both have near identical power curves, but check out the a/f ratio difference.....this also goes to show that someone elses map may now be spot on for the exact same mods...
sorry my scanner sucks...: stock with air lid removed, sparky removed and speed sensor disconnected
this next one is a bone stock bike to a 1.5 mod with the speed sensor disconnected.....un tuned with the map from the power commander site
Yea she leaned out pretty bad. We are messing with a closed loop system that should be coming out for the Raptor soon and bone stock with the closed loop system with nothing removed it gained 5hp!!
DL you seem to have the dyno at the ready Do you know where i can find a map for
Full HMF
no S/A
prodesign intake with K&N
DL, did u use the exact map from power commander.com for no lid, and no sparky on this test? the reason i ask is because that is the map i have and its great! but im now adding a pro design intake with the k&n and im wondering if it will lean it to much. i got some maps for the pro design, but looking at the numbers, they( the new maps) look leaner. what do u think?
1 - 10 of 10 Posts
