1 - 8 of 8 Posts
· Registered
Hey just wanted to start a thread here about sprockets.....Does anyone have any input on whats "best" for different applications of riding. ie: duner's what do you guys prefer, Trail riders, what do you guys like?
I am a recreational rider, some sand, some trails, some flat wide open racing and I use a 15t front and stock 38t rear with the big three mods. I enjoy it a lot and find that I'm not pointing at the stars every time I hit the gas. I would probably switch to the 14t if I was going to be doing a day trip of trail riding, the 15t puts you in a weird rev range between 2nd and 3rd so you tend to shift between the two a lot, or you run with high revs in 2nd.
Hope this thread takes off.......I know a few of you guys have a chart with the ratio's for each gear with different sprocket combinations, if you wouldn't mind putting that up for all to see that would be very helpful.
Thanks all you guys, lets keep making this site even better. :rockon: :beerchug:
STEVE
· Registered
If you have never tried a 13t on trails, do so. Its a blast. Currently I have a 15t though.
· Registered
Discussion Starter · #6 ·
Does anyone have the chart that shows the gear ratio when you change sprockets?
Now I know someone on here has the gearing ratio for different sprocket set-ups. I couldn't find it on the "other" web site but I know it's there and I think it's very helpful to determine where you want to be geared based on certain tire sizes. this will only help this site to be as informative or more so than others. Maybe someone else knows where that thread is that I'm talking about????
· Registered
Discussion Starter · #8 ·
PERFECT!! thats exactly what I was looking for....in case you guys can't see this chart at work, here ya go!! Thanks Seven00!!!
(FS=front sprocket RS=rear sprocket GR=gear ratio)
Raptor 700R Gearing Sorted by front sprocket
FS RS GR 18"tire 20"tire 21"tire 22"tire
13 36 0.3611 6.500 7.222 7.583 7.944
13 37 0.3514 6.324 7.027 7.378 7.730
13 38 0.3421 6.158 6.842 7.184 7.526
13 39 0.3333 6.000 6.667 7.000 7.333
13 40 0.3250 5.850 6.500 6.825 7.150
14 36 0.3889 7.000 7.778 8.167 8.556
14 37 0.3784 6.811 7.568 7.946 8.324
14 38 0.3684 6.632 7.368 7.737 8.105
14 39 0.3590 6.462 7.179 7.538 7.897
14 40 0.3500 6.300 7.000 7.350 7.700
15 36 0.4167 7.500 8.333 8.750 9.167
15 37 0.4054 7.297 8.108 8.514 8.919
15 38 0.3947 7.105 7.895 8.289 8.684
15 39 0.3846 6.923 7.692 8.077 8.462
15 40 0.3750 6.750 7.500 7.875 8.250
Raptor 700R Gearing Sorted by Gear Ratio*
FS RS GR 18"Tire 20"Tire 21"Tire 22"Tire
1 - 8 of 8 Posts
