Huh, I didn't realize that knobbies were a 5hp loss. I also didn't realize a 15T sprocket was a HP loss. IF that was the case, why would anyone run different gearing? I can't figure that one out :think: BUT I'm also the one that does NOT have a dyno and paid 110 bucks to get a dyno tune. (on holeshot h-d's which got 53 hp with a single & HCII, so I don't feel so bad now!)Exactcly....DMC's constrict, knobbies lose 5 HP, and a 15t is harder to pull. Therefore resulting in a huge power bog.
It's a trade off, if you like more torque then the HCII is good, if you want more power and over rev, then the HCIII is good as well. You ride a bike that has 686cc.... there's no such thing as killing torque :thumb:I was under the impression that unless your a sand nut and run at 7K+ all the time, that a stage III is killing more bottom end then it provides up top.... What kind of increase would i be lookin at If I went from stage II to stage III with 11:1, P&P, PCIII, Dynatek, Aluminum intake and Barker Duals??
I do lots of mid to upper rpm crusing, not too much down low. Put I dont want the thing to turn into a 2-stroke powerband, ya know??
OK, Dan I'm alittle confused here. We had bikes at the Glamis Raptor Rally with 11:1 piston, +3 Throttle Body, PCIII, Monster full dual exhaust, Stage 2 cam, Intake, air box lid removed and they made 55 HP. How should a "stock bike" with the mods you listed on the bottom of the Dyno sheet make ONLY 5HP less?after some retuning....almost 50 mhp on a stock pipe
You have to remember Johnny..... DL's a tweaker.... and has a severe case of A.D.D. When it comes to horsepowerOK, Dan I'm alittle confused here. We had bikes at the Glamis Raptor Rally with 11:1 piston, +3 Throttle Body, PCIII, Monster full dual exhaust, Stage 2 cam, Intake, air box lid removed and they made 55 HP. How should a "stock bike" with the mods you listed on the bottom of the Dyno sheet make ONLY 5HP less?
How much HP gain should you get by doing the spark plug mod, unhooking the speed sensor, adjusting the accelerator pump function on the PCIII? I wouldn't think it would be close as a 11:1 piston, +3 throttle body and full dual exhaust.
I'm only asking to understand more about making power for our Raptor 700's.
-Johnny
