1 - 6 of 6 Posts
do i need to turn or remove the carb to get the starter out? it just seems like a pain for sure.. how do i remove it
? any heads up will help.. thanks
you dont have to pull the carb but i removed the tube between the carb and airbox!
heck all your battery/electrical connections before looking at the starter. Just make sure your battery terminals are both clean. I would also see if there is a connector for the key switch and also the one on the handlebars.
1 - 6 of 6 Posts
