1 - 14 of 14 Posts
Changing out the carrier bearings right now and Im having a heck of a time getting the axle nut off. Loosened both pinch bolts, penetrating oil and even heat and it still wont budge. Tryin to losten it with a big pair of pump pliers right now.
Any suggestions?
ROTM Administrator
Any suggestions?
I figures, Mine keeps coming loose and yours is stuck, I torque it to 175 ft lbs. and tighten the 2 little allens and every couple of rides it's loose again:cunfuz:
I spent an hour dicking with a huge cheater bar and pipe wrench before I admitted defeat and heated the piss out of it then soaked it down with PB blaster and let it set over night. It was finger tight by morning!
1 - 14 of 14 Posts
