I'll try to get pics if I can remember to, I've been real busy lately and haven't got on here much! I took about 1 cm off the end of each wire in the switch, and cut about 2 cm off of the orange coil wire. It should be the only single wire coming out, and it's orange, so not too hard to find. I cut the coating of the wire, not the whole wire. I then started the quad, and touched one wire to the exposed coil wire and the other to a ground spot, which is any bare metal on the frame that you can find. Make sure to keep have the switch disengaged, off, or otherwise apart as if you had come off the machine, and ground the wire first. If the quad dies, then you know that the wire that is on the coil is the "hot" wire and the other is a ground. This is how you will hook it up. I wrapped the end of the hot wire around the exposed coil wire and used electrical tape to secure it and keep out the elements. I used 3-4 in lenghts of tape and wrapped it seperately a few times to make sure that there was no way for water to make it's way in there. I then took an electrical connector and clamped it on the end of the exposed ground wire. I took out a headlight bolt, cleaned up a spot with my knife to ensure a good ground, lined the connector up to the hole, and reinstalled my bolt. It sounds lenghty, but only took me like 10 minutes to do. I realize some people have never done this before, so this is the easiest explaination that I have. I was originally going to tap into the kill switch, but gave up on that idea quick! You will need, a kill switch, knife/wire strippers (or use your teeth), electrical tape, and the proper tools to remove the hood, put the switch on the handlebars, and remove headlight bolt.
