is it possible to like put nitrous purge like they do on cars just for show, like when they purge it colored smoke comes out? i always thought this would kinda look cool at night
Guys, a purge system should be standard on any N20 system no matter what it is on. The color you are seeing is created by a purge nozzle with a colored LED on it. When you hit the purge bottom it lights up the led and makes the N20 looked colored when it comes out. A purge system is to make sure there are not air bubbles in the N20 line before using it.
Could we of both answered at the same time.:lol:The nitrous comes out illuminated by led's which makes it look colored. But sure it can be done.
just so you know nos doesnt burn. when it enters the cumbustion chamber the heat and pressure makes the nitrogen and oxygen separate and then more fuel can be added and burned creating higher pressure in the combustion chamber. i also believe the nitrogen helps control the burn process by making it more stablesounds cool to me. what if you could make it shoot flames like a fire breathing raptor dragon. sweet:rockon:
