Hey guys, i need some help. I have a raptor 700 2006 and it shift itself from 3rd to 4th gear when i go in high rpm in 3rd, no jumping or loud noises, it just skips to 4th and i can continue in 4th like nothing happened or just downshift back in 3rd, but if i give too much power it does it again. 3rd is the only gear that does it, all the other gears are good and hold, so i knew it was not the clutch. It does it since a long time and i continued to ride and never had any other problem, it never got worst, but i decided to open the motor to see what is going on, thinking that the teeth of the gear would be damaged or something, but the motor is all apart now, transmisson is out and i dont see anything wrong with them, i'm not an expert but everything seems like new to me...
I don't want to put it all back together without fixing it, so do you guys know what it could be other than the actual gears being bad ? What should i watch ?
Thank you
