i have a 2003 yamaha raptor 660r, i just bought three days ago and it only has a K&N filter. soo pretty much its stock. how can i make it faster? :hyper::disappointed:
Lots of things you can do. Depends on how much money and work you want to do. Common things are to put a high compression piston and hot rod crank. An easy and possibly cheap is out aftermarket exhaust on it. You could go in farther and get some new cams. A really easy thing would be to get some different sized sprockets.
Administrator
First thing is pull the K&N off before it destroys your motor. Put a foam filter back on. Next, clean the carb, change all the fluids to synthetic and get a hang for the quad before getting all crazy. The 600 is a fast quad in stock form. After that a pipe is the next step.
rehash.... I have an 03 limited with full Yosh exhaust, jetted carbs, drilled airbox and uni filter. thing is scary fast. Stomps most anything. jus sayin'..
