X2Premium pump gas here with stock compression
I know 91 Octane in my area is $4.20 a gallon right now, and the 110 Octane is $6.50. I think it depends how often you ride to get high compression or not.I have been eyeballing higher compression pistons for a while, but I am not sure if I want to just get a 686 and run pump gas still or if I should go all out and go to a bigger displacement, of course then I will need the dual exhaust and the fcr's and it will cost all kinds of money, I know it is worth it, but I am cheap.
x3Premium pump gas here with stock compression
I run premium pump gas on ALL stock motors, better fuel mileage and better for the environment!You really don't need premium with stock compression. You are really wasting your money because it doesn't burn it any different than 87. I am running C12 gas on 14:1. I could go oxyg and get an extra 3hp but it does just fine. it is really not that great to switch gas all the time!
If you really want to know about fuels go here:thumb:
http://www.vpracingfuels.com/vp_01_fuels.html
Actually, in the dunes my stock motor pinged frequently with 87 octane, worked well with 91. The load from the paddles going up hills in sand had too much load on the motor. You have to remember how large the combustion chamber is on all the Raptors, definetly not the most efficient use of combustion space. And oxy fuel will only net 1 hp and 1 lbs of torque across the whole power band, unless they got some trick magical shit now I haven't seen. :lol:You really don't need premium with stock compression. You are really wasting your money because it doesn't burn it any different than 87. I am running C12 gas on 14:1. I could go oxyg and get an extra 3hp but it does just fine. it is really not that great to switch gas all the time!
Ok let me see if I can explain this in lamens terms lol. Let's say your vehicle can run on 87 octane, the higher octane you go the less power it will make, why is that? Because the harder it is for the fuel to combust when you don't have the timing ignition or compression to combust it, ergo slowing flame travel. Now when you're making less power you're also making less Volumetric Efficiency on that size motor. The less efficient you make your motor the worse gas mileage it is going to get, same concept as a k&n and flowmasters giving better gas mileage. Or a tuner on a truck that advances the timing ignition to help spark that flame front in the chamber. My current small block dodge, a 340, gets 22 miles per gallon, and that's due to the compression I run, the camshaft and cylinder heads I mapped out, and the low 87 octane I use.I dont know what planet you are from pdub but, I get several miles per gallon more by using premium pump gas here in the state of PA! It isn't much but in the long run, it adds up!
I get 14 on 87 and 17 to 18 on 93 octane. My current vehicle has 135,000 miles on it, so do the math, it pays off when you go with the premium.
I run premium in mines:banana:!! But what if I decided to run 111 octane in a stock engine? Would it hurt anything:think:?You really don't need premium with stock compression. You are really wasting your money because it doesn't burn it any different than 87. I am running C12 gas on 14:1. I could go oxyg and get an extra 3hp but it does just fine. it is really not that great to switch gas all the time!
yes do not do that...that will be really bad for your motor..you will cause detonation and burn it up.I run premium in mines:banana:!! But what if I decided to run 111 octane in a stock engine? Would it hurt anything:think:?
Ya you cn run the cheap stuff and be ok. I would not run 111 you only need that with 12:1 compresssion and above:thumb: You are not burning your fuel right with 9:1 compI run premium in mines:banana:!! But what if I decided to run 111 octane in a stock engine? Would it hurt anything:think:?
http://en.wikipedia.org/wiki/Brake_specific_fuel_consumptionOk let me see if I can explain this in lamens terms lol. Let's say your vehicle can run on 87 octane, the higher octane you go the less power it will make, why is that? Because the harder it is for the fuel to combust when you don't have the timing ignition or compression to combust it, ergo slowing flame travel. Now when you're making less power you're also making less Volumetric Efficiency on that size motor. The less efficient you make your motor the worse gas mileage it is going to get, same concept as a k&n and flowmasters giving better gas mileage. Or a tuner on a truck that advances the timing ignition to help spark that flame front in the chamber. My current small block dodge, a 340, gets 22 miles per gallon, and that's due to the compression I run, the camshaft and cylinder heads I mapped out, and the low 87 octane I use.
Now you might be wondering why your test showed differently? Unfortunately there are alot of variables that can go into that. Right down to how accurate is the gas pump when measuring the fuel.
But hey, Seven00 is you don't believe I listen to your theories as soon as you know what BSFC is, because that is the key information in what makes gas mileage in an internal combustion motor. :thumb:
Nice google search :lol:
