1 - 5 of 5 Posts
Hi people please can someone advise why my rap 700 2016 will not start . The electric start is working but won鈥檛 fire up . The engine light appears whilst cranking it over ?? I had her out today was fine then a friend wanted to sit on it . She鈥檚 a pretty large gal 馃榾& now it won鈥檛 start
Do you hear the fuel pump prime when you turn key on ? If not check connections on tank or relay in back. Did you check to see if you have spark ? Do some basic trouble shooting, could just be a coincidence or maybe a connection got crushed ?!?!?!?
Thanks for your advice I鈥檝e done everything you said & found out it was the tank relay . Thank you for your help . Much appreciated
Had similar problem couple of months ago and turned out the fuel pump. Replaced the pump and fired right away.
1 - 5 of 5 Posts
